Turbo build 2009 tsx k24z3
Old 04-04-2013, 05:35 AM
UTAH TSX's Avatar
Here we go i think i will be the first gen 2 tsx turbo build nothing is available all custom fabricated by me tunning and parts to be used by cortney green racing in salt lake city utah (one of the best honda tuners around) turbo manifold is almost done (making 2 and a jig to make more) using precision turbo's 5858 with t4 flange it is bigger for better flow from intigrated exhaust manifold 3in down pipe 2.5 hot pipe 4in intake pipe using tial 44 mm wastegate tial 50mm blow off valve deleting massair flow sensor will use intake air temp off s2000 i have 31 by 12 3 inch thick intercooler in and out on the same side have hondata flash pro
pics comming soon
(no i will not turn caps off use periods or spell check im an old honda tech typing skills=none)
Old 04-04-2013, 09:12 AM
2010 TSX
bagwell's Avatar
hasn't a Civic Si been turbo'd? same motor right?
Old 04-04-2013, 09:43 AM
UTAH TSX's Avatar
Nothing fits we have a motor mount where the turbo sits on the civic si the motor is hung from the top with a dog bone on the oil pan on the civic
this will also fit 2008-2012 accord when im done
Old 04-04-2013, 11:04 PM
UTAH TSX's Avatar
Pictures turbo
Pictures i hope
Attached Thumbnails Turbo build 2009 tsx k24z3-001-2-.jpg   Turbo build 2009 tsx k24z3-20130404_171558.jpg   Turbo build 2009 tsx k24z3-tsx.jpg   Turbo build 2009 tsx k24z3-tsx1.jpg   Turbo build 2009 tsx k24z3-001.jpg
holy frog (02-04-2016)
Old 04-05-2013, 12:22 AM
TRP
TRP's Avatar
This could get real interesting.
Old 04-05-2013, 07:41 AM
JR_Rider's Avatar
Subscribed!
Old 04-05-2013, 03:17 PM
count.chokula.d_brasil's Avatar
nice
are you gonna run an external electric oil pump and reservoir for the oil to cool the turbo or tap it on the oil pan?
Old 04-05-2013, 03:22 PM
UTAH TSX's Avatar
I have been thinking about using the port on the back of the block where the oil filter WOULD be. On the TSX it's underneath, there is a block off plate there. Does anyone know if that is a spot where I can get oil from? (sandwich plate, then put the block off back on the plate) I've been meaning to take one off at work but haven't found a warranty job yet. As for a return the current choice is taking off the time tensioner cover and welding a fitting to that.
Old 04-05-2013, 08:07 PM
UTAH TSX's Avatar
More parts the list is getting smaller
Old 04-07-2013, 12:32 PM
do you know if out engine has piston jets/coolers under it?
Old 04-07-2013, 12:57 PM
Vancouver B.C.
ttk5's Avatar
This looks like its going to be an amazing build. I'm sure it will inspire many of us who have been dreaming about doing the same, but didn't have big enough balls to pull through like you are. PROPS!
Old 04-07-2013, 04:38 PM
UTAH TSX's Avatar
Yes they do have oil srayers for piston cooling.
Old 04-08-2013, 02:45 AM
Ridiqueulous's Avatar
can't wait to see progress!
Old 04-08-2013, 12:07 PM
optimusaccord's Avatar
Will you be selling this solution as a kit of types? I was at the point of giving up and purchasing the CTE supercharger setup... I would prefer Turbo BIG time.
Old 04-08-2013, 08:15 PM
Also, I have capital to secure my kit. If that's the case.
Old 04-08-2013, 09:00 PM
UTAH TSX's Avatar
Waste gate 1/2 way done with mock up
Waste gate 44mm tiel
Old 04-08-2013, 09:14 PM
UTAH TSX's Avatar
Optimusaccord i'm still debating on how to sell it will be at least manifold and down pipe it will be so much easier to use a internal waste gated turbo like the borg warner efr turbos if you want to do this style it could be much faster would require sending me the turbo for build not ready to take any money yet i dont see there being a huge demand for this so you will most likley be the first
Old 04-08-2013, 11:26 PM
I would have no issues running a Borg Warner EFR turbo, as it would make the install much cleaner.
Do you work at an Acura dealership? If so, could you help me determine if a regular k series LSD will drop into the 09 tranny case, with a 10 bolt ring gear and 10 honda oem ring gear bolts? Before I start picking everything up, I would like to have some amount of certainty before I pay to have the transmission removed.
I have talked to a few aftermarket companies, and they "believe" it will fit, but no one has tried it yet. The 11 TSX and 12 si have very similar part numbers, so I think it should work... but, should and will are about 1200 dollars too much to just try it on a whim.
Thanks for any help, and if you do want to produce the kit, let's get a dialog going. I have had a few places say they were interested to make a kit, but then nothing ever occurred to move it forward.
Old 04-09-2013, 09:35 AM
VortexBlueTSX's Avatar
+1 I will be the second right after optimus...I am really interested in this
Old 04-09-2013, 02:25 PM
So, what is the expected timeline for this?
I have been pretty patient up to this point, so I'm not worried about waiting a bit longer. But would like a time table. Also would like to budget it out and set a calendar for when to get LSD and clutch and flywheel in by...
Old 04-09-2013, 04:10 PM
MirozS's Avatar
i have been waiting and waiting for somebody to do this, a local shop quoted me at 11,12k due to custom fabrication and welding for proper fitment, cant wait to see the outcome and hopefully will be the next person to get this done
Old 04-09-2013, 09:42 PM
UTAH TSX's Avatar
Optimusaccord I work at Larry h miller honda in sallt lake city utah.I'm 48 years old been a technician since I was 17. I raced stock cars street stock to late models for 13+ years built many chassis, headers, exhuast systems,complete cars, over the years (not to good at writing these posts my spelling and penmanship suck sure you all noticed)
As for time line the sooner you get me a turbo and some materials the better that way I can do youre manifold and down pipe at the same time as mine and test fit on my car in the next month and ship it to you max 2 months from now if you have a tuner talk to him on turbo choice (must be internal waste gated) I like precision turbos oil cooled and lubricated no coolant lines to mess with. e mail me at scotts1lowtsx@yahoo.com
---vortex blue tsx-- I knew you would be interested youre car is bad ass -----ttk5-- I have been stalking youre car it looks really good I want to make my white tsx look as good as yours---mirozs the whole turbo setup will be about 1/2 or less of what you were quoted even with flash pro and a good dyno tune and all quality parts no knock off junk now you could go crazy on parts and spend more. the manifold and down pipe will be about $1,000-$1200 (add $125 for fake converter to fool the emission tester) intake pipe and filter about $350-$450 still working on inter cooler and hot cold pipes not sure on $$ for those yet turbo oil line and drain kit close to knowing cost.
VortexBlueTSX (04-20-2013)
Old 04-10-2013, 01:24 PM
odus's Avatar
^^^ this man gives me hope for this car wish mine was stick i would tackle this maybe.
Old 04-10-2013, 01:53 PM
ROTAREDOM
ssjoeboe9's Avatar
Received 1,488 Likes on 1,058 Posts
Can't wait for engineering money lol
Old 04-10-2013, 03:26 PM
MirozS's Avatar
this is awesome, the local shops were ballparking way to high and knowing that it can be done for way cheaper is just great only problem is i live in upstate new york so it would be hard to build it
Old 04-10-2013, 10:05 PM
UTAH TSX's Avatar
Intercooler mounted
Barely fits bigger is better removed air filter silencer box planning piping
Attached Thumbnails Turbo build 2009 tsx k24z3-1.jpeg   Turbo build 2009 tsx k24z3-5.jpeg   Turbo build 2009 tsx k24z3-6.jpeg   Turbo build 2009 tsx k24z3-2.jpeg
David Robinson (05-03-2013)
Old 04-10-2013, 10:13 PM
UTAH TSX's Avatar
my car is an auto to much traffic in salt lake city for shifting i have not seen a single transmission go bad on 2009+ tsx or 2008+accord i belive it will hold up shooting for 400 whp
The following 3 users liked this post by UTAH TSX:
gaTorSXtasy (04-15-2013), thunderbt3 (04-10-2013), VortexBlueTSX (04-20-2013)
Old 04-11-2013, 09:19 AM
I'll construct an email when I am home this weekend, or maybe on the plane home if we have internet in flight.
I am open to suggestion on turbo's, do precision offer the internally wastegated options? I am open to that, I want ball bearing unless you are against that?? I would like 350 - 400 whp....
Old 04-11-2013, 01:43 PM
SeeYou2Crew #2
ed_423's Avatar
nice intercooler
Old 04-11-2013, 09:50 PM
UTAH TSX's Avatar
Precision 5858
Got the tubo I will be using today its a precision 5858 with t4 inlet 3in vband AR 58 compressor side is 4.0 in 2.5 out
Attached Thumbnails Turbo build 2009 tsx k24z3-7.jpeg   Turbo build 2009 tsx k24z3-8.jpeg   Turbo build 2009 tsx k24z3-9.jpeg
Old 04-11-2013, 09:58 PM
Goodbye.
TSXy Luster's Avatar
Old 04-12-2013, 07:24 PM
UTAH TSX's Avatar
Final mockup finished
Finished it all fits perfectly -down pipe -manifold-wastegate-what a mother i have spent many days to get to this point its comming together will post pictures of it all out of car later
Attached Thumbnails Turbo build 2009 tsx k24z3-imag0140.jpg   Turbo build 2009 tsx k24z3-imag0150.jpg
The following 2 users liked this post by UTAH TSX:
99blackhatch (08-29-2013), holy frog (02-04-2016)
Old 04-12-2013, 08:06 PM
UTAH TSX's Avatar
Out of car
Ready to tig weld and finish jig
Old 04-12-2013, 08:09 PM
UTAH TSX's Avatar
Crap no pictures
How do i go back and edit a post or add pictures to it
Attached Thumbnails Turbo build 2009 tsx k24z3-20130412_172836.jpg   Turbo build 2009 tsx k24z3-20130412_172844.jpg
Old 04-12-2013, 10:46 PM
MC MiYoung3269's Avatar
Received 1,000 Likes on 712 Posts
You can only go back and edit within 15 minutes after posting that post. After that, you'll have to post a new reply.
And nice progress you've got going
Old 04-12-2013, 10:55 PM
JR_Rider's Avatar
Hawt!!!!!!
Old 04-13-2013, 12:47 PM
Goodbye.
If everything works great and the price is right, I would drive out there to have you put one in my car lol
Old 04-13-2013, 01:21 PM
UTAH TSX's Avatar
I just hope youre avitar picture is you - I'm in utah google sister wives tv series
Old 04-13-2013, 02:44 PM
odus's Avatar
looks good cant wait for vids of this
Old 04-13-2013, 04:39 PM
ROTAREDOM
ssjoeboe9's Avatar
Are you gunna leave it sleeper mode? No other mods? Cause that would be awesome.
Quick Reply: Turbo build 2009 tsx k24z3
