Lip Spoiler install.
7# werC 2uoYeeS
There's a drill way and a non-drilled way. The dealerships install it by drilling holes on the ends of the lip spoiler and connecting it through the holes and using tape.
The non-drilled method just uses tape. Not as secure as drilling but from everyone who's done the non-drilled method, I have yet to read about one falling off or getting pulled off. If you feel like you might remove it later go non-drilled.
When installing the tape, be sure it is above 60 degrees out. 3M tape doesn't work at 45 degrees. Ask me how I know.
I got my spoiler from the spoiler store on ebay. The paint match was perfect. After I reinstalled it on a warm day, it seems very solid now. The ebay kit included some hardware for the drilling method of installation, but I feel confident that the tape will be just fine. I replaced the original mounting tape with 3M brand tape, just for added piece of mind.
That being said, I do consider it to be removable.
My ebay one keeps peeling off on the corners for some reason. I think because the weather here is extremely biopolar like 30 degrees from 6-11 then 70 from 12-5 then 40
ROTAREDOM
OP... I made a DIY for this if you wanna see the install(non drilled) just search for it. Or look through any threads started by me.
