| New! Use your Facebook to securely log into this site, click logo to login |
| Welcome to Acurazine.com! |
Thread Tools |
#1 | ||||||
Former Audio Mod
FAQ & Instructions: Aux Audio Adapter - From Selection to Completion
Milano Red/Parchment, AT, Non-Nav, Fog Lights, Rear Spoiler, Splash Guards, Moonroof Wind Deflector, Wheel Locks, Wood Grain Kit, Audio Aux Schalliol TSX Gallery Production No. 12555 |
| Sponsored Links | ||
#2 |
Nice Job!!!
CG/EBONY/5AT/NON-NAVI ;) |
#3 |
Moderator Alumnus
Good piece of work schalliol ... good to have you on board as part of our mod staff
Acurazine Owner and Enthusiast 2008 Acura TL and 2008 Honday Odyssey |
#4 |
Mega Moderator
Great stuff!
#5 | |
Former Audio Mod
Re: Re: FAQ & Instructions: Aux Audio Adapter - From Selection to Completion
sheik28, provench, and fdl, thanks very much, I'm glad to be here. It's excellent to see other people who are as into the cars and other details as much as I am.
#6 |
Mega Moderator
so schalliol...are you running this cool ipod setup through the stock speakers? Just wondering if you have done anything to improve the sound. I'm thinking the best bang for the buck thing to do is swap out the front door speakers.
#7 | |
Former Audio Mod
#8 |
Nice job with the FAQ, and with the iPod install!
#9 |
Hey schalliol - great work! Looks real professional. I have a couple of questions:
First, how does it sound? As good as listening to a CD? How did you get the interconnect cable from the adaptor to the center console pocket? And are the other sides of the RCA plugs from the wall plate in the cup holder? |
#10 | |||||
Former Audio Mod
![]() Quote:
#11 | |
Master in Science
1999.5 Jetta GLS 2004 TSX 5AT NAVI Currently car-less... |
#12 | |
Former Audio Mod
#13 |
Thanks for the info. My iPod works great in my car now.
I would add one thing to your faq. In one of the other threads someone recommends getting a Ground Loop Isolator from Radio Shack. This is a must so you dont get any engine or ground noise. I tried both ways and it made a big difference. |
#14 | |
Former Audio Mod
Hmm, I could add the isolator, but I have ZERO noise even at 35 when my iPod isn't playing, I don't even know that the head unit is on. Where did you put the isolator? Any pics?
#15 | |
Registered AssHat
I put the isolator right next to the SNHOND3 behind the top console bin. |
#16 | |
Former Audio Mod
#17 | |
Registered AssHat
#18 |
Former Audio Mod
makes sense indeed.
#19 |
I heard engine noise when I was just on batteries and engine noise + gound loop noise when using the charger.
The ground loop isolator took out all the noise. |
#20 | |
Former Audio Mod
#21 | |
Registered AssHat
I actually go mine from CarToys, but it looks just the same. From my Neuros (iPod like) to the headunit it looks like this: Neuros -> 3.5mm to RCA cord -> RCA wall jacks -> RCA 3ft. extender -> Ground Loop Isolator -> SNHOND3 -> headunit. As a note, I got all my cables from Target too. Cheapest place to find "normal" cables and not the $50 "MONSTER" cables that I could give a rip about. |
#22 |
I found that a GOOD SOLID SHORT GROUND, attached to the chassis of the vehicle eliminated any audible noises in my system. This ground was used as the DC return line for my XM Roady. I picked it up from a bolt under the tunnel cover when I extracted DC power from the aux power receptacle. Without this good ground, I was getting annoying noises. Give it a try. I did not use a GLI.
#23 | |
Registered AssHat
The reason why there are grounding issues with the aux, is due the power noise (spark plugs, etc.) creating high currents to ground. If you connect a wire between the ground of an iPod and headunit (through the RCA cables) you have just changed the impedance. The way a GLI works is by putting an RC filter between the two grounds of the RCA plugs. Thus you have broken this line and both the headunit and iPod now use chassis ground as a reference. |
#24 |
hand free phone kit
Can someon tell me if the SNHOND3 works with the hands free kit from Acura? I just ordered the kit and I would also like to install the audio adapter while I have the car torn apart.
I tried posting the directions for the phone kit, but they were too big. It looks like the phone adds a single wire to the 20-pin wire harness that plugs into the tuner and has a Y connection for the 20-pin cable that plugs into the amplifier. Can any of you SNHOND3 experts tell me if this will work? Thanks.
04 TSX CG/6sp/nav 02 MDX Red/nav |
#25 | |
Former Audio Mod
Re: hand free phone kit
Lung Fu Mo Shi and Ellis Dawson, thanks for the posts, I'm trying to determine what I want to do.
#26 |
Thanks for the response schalliol.
You are correct, the phone adapter has a single cable that snaps into the wire harness, which in turn, plugs into the pre-amp output from the head unit. I am guessing this is how the radio is muted? The other end of the 20 pin cable then connects to the phone wire harness. From the phone wire harness a 20 pin cable is plugged into the amp. I know this probably doesn't sound right because I am having a hard time trying to describe it. I don't think there is anything from the phone adapter that needs to be sent to the radio, other than the mute cable. I don't think the AUX button needs to be pressed for the phone to work. The more I think about it, the more I think it will work. If anyone wants a copy of the pdf file, PM me and I will email it to you (766K). |
#27 |
Will the storage tray a good place to store the iPod?
#28 |
Former Audio Mod
Did you check out my pics? It's great for me.
#29 |
I mean the storage bin that's under the a/c.
#30 | |
Former Audio Mod
#31 |
What's the difference between the Monster iCable and other RCA to minijack cable?
#32 | |
Former Audio Mod
#33 |
Just the quality?
How come Monster cable has a specific "iCable" for the iPod and have some other RCA to minijack cable with different name? |
#34 | ||
Former Audio Mod
#35 |
Which means any good quality cable will do the same thing as the iCable, and it will also work with any minijack devices?
I can get a good quality cable easily, but not the iCable. That's why I want to it clear first. Planning to order the SNHOND3 on Dec. 1 (Pay-day). ![]() |
#36 |
Former Audio Mod
Yep yep! If you have any doubts, re-read the FAQ at the beginning. I haven't added it yet, but if you want to charge it up while playing, you'll want the $15 ground loop eliminator from Radio Shack mentioned here. How are you installing your system, are you going to do the jacks like I did or in some other way.
#37 |
I'm not sure if I want the car charger. Is it really a must have item? If not. I'll do the install myself, just drill a hold at the storage bin and plug in the iPod everytime I go into the car. Otherwise, find a store to run the wire to the armrest compartment, so I can use the car charger.
By the way, just bought the iCable. I told the sales from FutureShop what I want and he said the iCable is one of the best from the market. |
#38 | |||
Former Audio Mod
#39 |
I'm afraid I'll forget to charge too!
Thanks for all the advices!!!!! Can't wait for the pay-day, just order the SNHOND3 yesterday. |
#40 |
Former Audio Mod
Updated the FAQ, included ground loop isolator info, as well as info on the ICElink
| Tags |
| 08a310e1010, acura, add, albuquerque, audio, aux, cable, cd, connector, convert, ipod, mp3, player, radio, removal, stock, tsx |
| Thread Tools | |
